building an executable with many layered VIs
Hi rob
Here is the programme.
cheers
herbie
Message 11 of 27
(1,200 Views)
Hi Herbie,
Could you please let me know which VI is your top level one?
Message 12 of 27
(1,196 Views)
Hi Rob
The top level VI called 'X7145 DCX T Case r2.0' is in the folder T case Main.
cheers
Herbie
Message 13 of 27
(1,194 Views)
Thanks Herbie, just a bit more information I require from you, are you using any specialised user libraries for this that I require to open it? If not then if you could let me know the modules you are using for this VI that'd be great.
Thanks in advance,
Message 14 of 27
(1,191 Views)
Hi Rob
The only extra modules used are a SCXI1102C, Daq card and Compumotor Plus drive and linear motor.  The latter is initialized/set-up from the second screen that appears.  So I am assuming that you may not be able to run the programme pass this screen.
cheers
herbie
Message 15 of 27
(1,185 Views)
Hi Herbie
I have just taken a look at the file that you attached. There is no project file there. Are you building your application from a project?
In your project file you should have all the sub vi's that you created under 'my computer' not under dependencies when you build your application. This could be why it is not working. I have attached an image showing whare they should be.
Can you attach you actual project file?
Regards
Beejal S
NI UK & Ireland
Message 16 of 27
(1,148 Views)
Hi
you are correct the sub vi's are not included in the project tree.  I will try what you have suggested and post the results.
Thank you Herbie
Message 17 of 27
(1,144 Views)
Hi
Please look at the project file and see if it is viable
cheers
Herbie
Message 18 of 27
(1,131 Views)
Hi Herbie
I can see that you have created two executables. Are the Level Durability and Durability vi's supposed to be linked in any way? Or are they completely seperate applications?
Beejal S
NI UK & Ireland
Message 19 of 27
(1,113 Views)
hi
They are two versions of the same programme. One uses slightly modified versions of certain VI's in the directory. These modifiedc versions also have lever in the title. Hope this answers your question.
Cheers
Herbie
Message 20 of 27
(1,102 Views)
