building a stand-alone application
I am running LabVIEW 2009.
I'm trying to build a stand-alone application.
I've selected the additional installers for NI-DAQmx 8.9.5.
When I build the installer I get a message
"Distributions Needed"
 NI LabVIEW 8.6.1 real-time Module
NI Measurement Studio 2009 for Visual Studio 2005
NI Measurement Studio 2009 for Visual Studio 2008
I've tried all the discs that I have but I can't find these files.
(2,755 Views)
In the dialog that let you select the DAQmx as an add-on installer you can also select where the files should be taken from. Hopefully you can get some other disc with the right info.
Ton
My LabVIEW Ideas
(2,723 Views)
Hello dh2o,
When adding the DAQmx 8.9.5 installer to you executable, you need to change the installer type to one of the partial installs. The full install will include support for the driver in several different programming langauges so when you choose a partial install it will only create an installer for a select part of the driver. I have updated my machine to DAQmx 9.1 where they separated this out to reduce confusion. I don't remember which one it is but you can find this out in the distribution title for that particular installer.
JimS
Jim St
RF Product Support Engineer
(2,697 Views)
