build window size
Something I’ve always wondered about!
Is there a way to fix the window of a built application to your front panel. I.e. if for example my front panel consists of a tabbed container, which in turn has various instruments, dials etc. How if possible, would one configure the build to ensure the built application’s window was only ever as wide and as tall as the tabbed container. Jus now for example, once i build it, I’m still able to scroll left and right which I don’t want.
(3,007 Views)
Change the Window Appearance of the VI:
Christian
(2,999 Views)
If you want to be able to resize in edit mode you can programatically set the resizable property. Also if you right click on the scrollbars you can set the vertical, horizontal, or both scrollbars to be off when the vi is running.
LabVIEW 2012
(2,995 Views)
cheers guys, i will try these on monday. Thanks
(2,989 Views)
