build waveform
See attatched .jpg. Is it a simpler way to build this plot?
I want to plot datas from 3 different measurements in 3 graphs, with the system time on the x-axis. The problem is that some samples are missing and therefore the time between samples can vary.
(3,353 Views)
Hi Christian,
it seems you already have chosen the simplest type of waveform building. (Btw. please save your pics as real jpg or even better as PNG).
For your second question:
The waveform datatype is made for equidistant samples. If some samples are 'missing' you get in trouble: either the timestamp is not correct (as it gets calculated from t0 and dt) or you have to fill in the missing samples.
(3,344 Views)
Thnx,
Another question: I want to save parts of the datasamples to a file which can be opened in excel. When a button is true I want the data which goes to the chart to also go to a file. 🙂 I`ve been struggeling with this, but can`t seem to find a good solution...
Help?
(3,333 Views)
Hi Christian,
you can do it like this:
I used LV7.1 for this example, in LV8+ you can/have to use the newer file functions. There is also a 'Write to spreadsheet file' function which also does the formatting of the data.
Message Edited by GerdW on 11-02-2006 04:13 PM
(3,322 Views)
