build spreadsheet string from 2 substrings
Hi all
I am trying to concatenate 2 arrays of strings. The first array contains 4 numerical values in string format and the second array contains time value in string format. What I am trying to do is to concatenate (?) these 2 arrays so I can get this : val1 val2 val3 val4 timestr          in order  to produce an excel report ..
I tried to use the concatenate strings function but i get : val1 val2 val3 val4
        val1 val2 val3 val4
        timestr
        timestr
I attach my vi if anyone wishes to help please do...
Thanks very much
Ioannis
Message 1 of 8
(3,680 Views)
I have got it to work for you.  You will still need to clean up some of the things no longer needed.
Message 2 of 8
(3,673 Views)
Hi Tom thanks for the reply. I am running LV7.1 and I can't run your VI...its 8.2...
Message 3 of 8
(3,667 Views)
here is a picture of the changed code.  I don't know how to save to versions earlier than 8.0!
Message Edited by Tom Haggerty on 10-18-2007 07:20 AM
Message 4 of 8
(3,665 Views)
Thanx Tom I'll give it a go and let you know...
thanks again
Message 5 of 8
(3,657 Views)
Here it is in 7.1 just in case.
Jim
LV 2020
Message 6 of 8
(3,646 Views)
OK guys with your valuable help i got it working..
thanks both of you again...
Ioannis
Message 7 of 8
(3,635 Views)
I would suggest reconsidering the way you've implemented your code. As it is, you're carrying around 5 arrays in separate shift registers. It seems that all you're doing is appending a string to an indicator. You can accomplish this by simply having a single shift register which is the string, and you simply append a string to it that you can easily build without having to deal with 2D arrays and transpose functions.
Message 8 of 8
(3,620 Views)
