build specification
hi all
I'm pretty new to Labview and are now using LV2009 and having some trouble with "build specification"
aren't there suppose to have 5 specifications, including EXE, Installer, DLL, source distribution, and zip file ?
why can i only find 2, namely Source Distribution and Web Service(RESTful) there?
thx
(3,978 Views)
Accepted by topic author jhr342002
Do you have the application builder installed?
see here
(3,961 Views)
Just like Muks said,
you might need to make sure if you have Application builder installed or have at least professional version installed to have those 5 function working as you expected.
Shawn
(3,935 Views)
(3,927 Views)
Hi guys,
I have a similar issue, although mine is a bit more complex. I see only two build specifications as well (Source Distribution and Web Service(RESTful)) despite the fact that I have LabVIEW Professional Development System installed. For some reason I installed the Application Builder as well separatelly as a trial version and now it has expired. What should I do? Should I reinstall LabVIEW? Any ideas?
(3,834 Views)
