build problem
I have a program called say PROG.VI inside a directory with other vi units.  Running the vi is fine.  When I go through the build proces using this vi all is well.
When I build using the LVproj route it builds ok but does not pick up some sub.vi units
(3,047 Views)
Please do not create multiple posts.
People are already trying to help you in your http://forums.ni.com/t5/LabVIEW/build/m-p/2139758#M692439. Instead of ignoring them, why don't you try to answer them instead?
(3,036 Views)
This is a duplicate.
http://forums.ni.com/t5/LabVIEW/build/td-p/2139728
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,035 Views)
