build hexadecimal string into byte array
Thank you again! Now I understand how to replace any of the elements in the command string.
Message 11 of 15
(851 Views)
The visual of the numeric representation for array constants on the block diagram was very helpful.  How can I do that?
Message 12 of 15
(839 Views)
I just show the label of the array element and manually type whatever is appropriate.
(Are you really sure you want the output as an array of U8 and not an array of U16 of half the length? It seems the original data is words (2 bytes))?
Message 13 of 15
(832 Views)
What an elegant idea.
As you noticed, I am not yet sure which approach I should use.  Both methods appear to work on a small sample of the command set. I believe the nibble is the original board data size but the PC is getting bytes back from the test program on the board.
Message 14 of 15
(825 Views)
A nibble (i.e. one hex character or 4 bits) is half a byte.
Your original data is in the form of 0xHHHH, i.e. two bytes (e.g. U16) and I would think it should be treated as such.
Message 15 of 15
(813 Views)
