build exe modem
Hi all,
I want to build an exe file (stand alone exe file).
My VI file has a communication to the serial port (modem).
When I build this file, a part of the program that relates to the modem doesn't work.
Please help me...
has
(2,883 Views)
How do you specify the port? Are you using Windows names (e. g. COM1) or VISA Resource names (e. g. ASRL1::INSTR)?
Is the exe running on the same machine or on another? You must be aware that the mapping from OS names to VISA names is located in the VISA alias file. You can set the VISA Alias names in MAX.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,880 Views)
I use the exe file in another computer with the same OS. I use windows names (COM 3).
(2,868 Views)
Windows names do not count.
Did you build an installer for your app? If you did, did you include the VISA run-time engine as an additional installer? This is a must unless you do a separate install of VISA or just the VISA run-time. You should also include MAX and export the hardware configuration from MAX.
(2,866 Views)
Thanks for your help.
(2,840 Views)
