build error
hi,
     i already installed diadem 11.1 evaluation version on my PC. after some days ago i un installed that diadem. i was done a project before and after installing the diadem.  but last 15 days before i removed the diadem from my PC. the same project file i cant able to build a installer, it showing some dll missing, when i seen the preview in application .exe there i can able to find lvalarms.dll and lvuste.dll. because of this it asking the ni.dist file. even i skip this error i cant able to installed the setup to other PC.
tell me suggestion. find this attachment
Balaji DP
(2,875 Views)
(2,858 Views)
I'm not sure what component you are actually missing there is, but as muks's link suggests, NI's installers look for whatever installed the most recent version of X.
One way I have got around this in the past (my case was related to DAQmx) was to download the latest version from the NI website. This causes the most recent version to be dependent on what you just downloaded, instead of the missing dist.
Shaun
(2,826 Views)
