build application
How does one create a labview application which will accept and pass arguments.
Any info would be appreciated.
M. Hubbard
(2,970 Views)
I guess you mean executable app, not a simple VI. If that is a case then
use LV ActiveX server capabilities.
If you have Application Builder (I assume you have it if you are talking
about exe) then you can specify in one of those dialogs ActiveX server name
for the application. Then your other app can use this name and ActiveX
RefNum control to set and read control values, etc.
"mark hubbard" wrote in message
news:39479012@newsgroups.ni.com...
arguments.
> M. Hubbard
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup
Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(2,970 Views)
If you were after a way to get command-line parameters into the run-time environment
with a LabVIEW executable under Windows, then this should do the trick (from the NI
Example Programs Database):
http://digital.ni.com/explprog.nsf/websearch/2afe980d2eea9d3d8025648700251f8e
John Lum
(2,970 Views)
