build a 3d graph
Hello guys...
I have one question.Actually i'm intresting about 3d recently. So, Could anyone help me how to make from 2d graph into 3d.Coz I have no idea how to wire it. thank u very much
(2,941 Views)
I am not sure why you are appending the same old data every 500ms, growing the table without limits. I think once is probably enough. Here's a quick draft, maybe it can give you some ideas.
(Since you have 3 1D arrays, you need a 3D curve graph, and not a 3D surface graph.)
Of course if your data actually changes continuously, you might want a 3D chart. In this case you should probably limit the history data. Please describe in more detail where the data is coming from and how you want to graph it over time.
(2,920 Views)
