bugfix for tab control showing element changes on all pages?
When I take a tab control, place a waveform graph on one page, go to another page and change the cursor position of the waveform I get cursors displayed despite the fact that I'm still on the other page.
There's a posted question concerning that, except it's about blinking buttons and not about cursors. The answer is that this seems to be a known bug and one could pass around it by setting the "visible"-property of the button to true only if the according page of the tab control is displayed.
Unfortunately, if I do that with the waveform graph, I can write data into it but won't get the axis autoscaled. Even if I use the autoscale-once-property afterwards I don't get all the graph displaye
d correctly.
So my main question is: Is there already a bugfix to that or when will there be one?
Greetings, Daniel Troendle
(2,966 Views)
Daniel,
This problem should be fixed in the LabVIEW 6.0.2 update, which is available from our website.
Please let me know if you continue to have any problems.
Sincerely,
Darren N.
NI Applications Engineer
(2,966 Views)
Hello Darren,
I experience the very same effect with LV 2015. The problem is present again.  I use the system Tab. When I move the mouse- Cursor over the Tab- buttons, the hover-effect is shown an the Ghost- Cursors disappear.
Greets, Dave
(2,517 Views)
15 Years.
Also do you have a screenshot, or VI that reproduces the issue?
(2,496 Views)
I was in a hurry, when I wrote my post, so I didn't provide you with more details. I apologize for that. Here are the datails:
This is the effect
This is the Tab-pane with waveform-graph
I found this code as to be guilty for the effect:
The workaround is now clear to me, because unnecessarily the Cursor List is cleared before the new List is set, but this combination leads to the printthrough of cursors.
And because I'm not able to attach VIs, here ist is as a snippet:
Greets, Dave
(2,456 Views)
