bug with "more text" feature in clusters?
I've started using LabVIEW 2019 SP1 and noticed that I can't expand truncated texts or numbers if they are in a cluster.  more text bug in cluster.png
Pre-LV 2019, I could click on the shortened field and expand it easily.  Now those resize marks aren't available.  I can pull the field out of the cluster and have the contents automatically expand to a readable size.  I have tried setting the cluster autosizing to 'None' but that didn't help.
Is this a bug in LV 2019?
(3,083 Views)
What kid of type definition is this cluster? Wonder if it has anything to do with that. Can you attach the ctl?
(3,072 Views)
Yes, I can.  Here it is:
(3,055 Views)
Just discovered when I drag the cluster out of my while loop, all controls expanded to fit the contents.  I could then drag it back into its original spot.
(3,039 Views)
All I can say is that I've run into this before, very occasionally. Hard to pin down what triggers it.
(3,030 Views)
So a bug then?  What's the latest bug report procedure?
(3,016 Views)
