bug with "FindFolder to LV Path.vi" on intel machine (OSX) - LV 8.2
there is a bug on intel machine
with FindFolder to LV Path.vi
which works as expected on PPC but don't give answer on intel machines
Message Edited by PlBee on 11-08-2006 05:23 PM
Message 1 of 16
(3,825 Views)
Can you give us a little more info, like a description of what is happening or not happening.  Attach some sample code showing the bug if you can.
- tbob
Inventor of the WORM Global
Message 2 of 16
(3,811 Views)
no need to sample code
just run FindFolder to LV Path.vi
the default input setting is kSystemFolderType
the PPC version returns ... the path of the system folder
the Intel version returns nothing
Message 3 of 16
(3,800 Views)
Where does "FindFolder to LV Path.vi" come from?  I couldn't find a VI with that name on my computer - I have LV 8.2.
Message 4 of 16
(3,793 Views)
vi.lib/Platform/FileManager.llb
Message 5 of 16
(3,792 Views)
Sorry I don't seem to have that llb .   Are you sure it is an NI one?
Message 6 of 16
(3,789 Views)
I get the same result. It returns Error Code 1 from PBGetCatInfo.vi. The Help suggests an invalid input parameter, but the inputs look very similar on the PPC and Intel machines. I have a Dual G5 and a MacIntel MacBook. Both with LV8.20 and OS X 10.4.8.
Note to pauldavey: The Platform directory contains platform-specific VI and .llbs. If you are not on the Macintosh platform, you may not have this VI.
Lynn
Message 7 of 16
(3,782 Views)
Hello and thanks for the heads-up!
Can any of you upload some screenshots that I can take to R&D?  I'm not terribly familiar with Macs, but if you could create screenshots of what it is supposed to look like (on the PPC) and on the Intel machine, it would be extremely helpful!
It is users like you that help us make LabVIEW a better and better product.
Janell R | Applications Engineer
Message 8 of 16
(3,762 Views)
sorry to repeat myself but it is not necessary to send screenshots nor test vi,
on a PPC machine, there is a result (default is path of the system folder)
on an Intel machine there is no result
Message 9 of 16
(3,738 Views)
Hello PIBee,
I just wanted to clarify - National Instruments does not fully support the use of LabVIEW on intel macs, so I do not have access to an intel mac in my department.  I was hoping to get a screenshot of the unexpected behavior and the error message that appears to include in a report to R&D.
Thanks and happy programming!
Message 10 of 16
(3,718 Views)
