buffered position measurement
Gathering position data from optical encoders very quickly. Hence I am using the buffered position measurement.vi as a basis. But when the gate signal calls the buffer the value of the buffer shown appears to be the last value read into the buffer. How can I get the entire data contained within the buffer upon execution with the Gate signal. I could then ideally stream this to disk and post process the data.
(2,453 Views)
This type of question belongs in the Measurement Devices >> Counter/Timer section of the Developer Exchange. As I see you have the same question there, I will go ahead and post the answer there.
(2,453 Views)
