buffered event counting
Hello
is it possible to configure a counter in such a way that it is placing
the amount of counted events on its source pin every (lets say) 25ms in
a buffer?
Do you know an example in labview which is using quadrature encoders
with high resolution? Is not a problem to count the events of them, but
its a problem to calculate the speed out of the messured pulse. The
system timing has not enought resolution and when you using
hardwaretiming you cannot read two counters at the same time.
Any idea?
Paul
_ _ ___ ___ HSR Hochschule Rapperswil;
| || / __| _ \ Paul Steiner, Abt. E7D; Oberseestrasse 10;
| __ \__ \ / CH-8640 Rapperswil; Switzerland; Fax:+41 55 222 4 400;
Tel:+41 55 222 4 222
|_||_|___/_|_\ EMAIL: p2steine@hsr.ch;
H
ttp://service.freepage.de/steinerst
Message 1 of 1
(3,265 Views)
