buffered counting 6008
Hi to all
Is here some one who can tell me how i can make a buffered counting of the  pulse count
This make sure i have a correct speed     count/time
The problem also is that i also need to see on meter how fast the speed is   i want to count as fast as possible  ,but the meter must run  at normal slow speed
Sorry guys i am new to labview   to please do not be so hard on me ,
Any one who could help me?
i want a TDMS file
Message 1 of 25
(4,093 Views)
First of all, next time you should think about posting this into the hardware forums.
Buffered Counting is not possible with USB-6008!
Christian
Message 2 of 25
(4,076 Views)
mm
strange    on page  6008 specs
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14604
here its says
Buffered Operations Yes
is counting not a operation?
Message 3 of 25
(4,064 Views)
Buffered operations for AI and AO, but not for counter operations.
Where exaclty tid you see this statement, I couldn't dinf it under the product site you linked.
Message Edited by Christian_M on 11-26-2009 07:15 AM
Message 4 of 25
(4,059 Views)
Cristian Hi
It is stated on section specifications
Message 5 of 25
(4,045 Views)
sorry here
you see it
Message 6 of 25
(4,044 Views)
I agree, this is really strange!
Though I know that buffered operations are not possible with a USB-6008. It's a very simple counter just for edge counting and it can only be controlled per software, due to that you can only select "On Demand" Timing. And for bufferd operations you will need a hardware clock.
Let me check whats up with that manual or if I'm really wrong.
Christian
Message 7 of 25
(4,034 Views)
As I said buffered counting is not supported with USB 6008. There is a mistake at the webpage.
However, could you explain a bit more in detail what you want to do, maybe we find another solution.
Christian
Message 8 of 25
(3,980 Views)
Hi Cristian
Well i count pulse´s to calc speed but i also need to display the speed at the same time,its already in a array but when i go slower as 1 sec in sampling data   i get faults  wrong speeds
if i want evry 0,1 the speed i get the error   and since it has no sample i have no idea how to solve this
Message 9 of 25
(3,969 Views)
Christian
Christian,
Can you file a CAR for correcting the same?
Message 10 of 25
(3,951 Views)
