buffered TDMS file still very large
Sorry - I'm not sure I understand what the criteria are. As I understand it, you can only write an array, not a cluster i.e. if I wan't to record data of more than one data type (e.g. a time stamp and some data) I have to do it in two separate write operations, which is effectively what I do currently. Also, you can't write more than one group at a time (?), so that means that I have to write one group and then the other, which sounds like its outside the criteria for "one header only"
thanks
Niall
Message 21 of 24
(1,016 Views)
Niall, I think your fix will be to go to "decimated" (default) layout instead of interleaved.  to do this for a single sample of N channels, drop a build array on the data wire to make the data array 2D, then transpose it so data are in rows, not columns.  This will work around the failure of NI_MinimumBufferSize to work with the interleaved layout.
-Barrett
CLD
Message 22 of 24
(1,006 Views)
You mean record each data point as another channel? This would obviously forgo the channel name metadata? To be honest - the simplest thing looks like its to do what I was going to do before I found out about this buffering which was just fill up an array with the data points and write this once when I change files.
Thanks for figuring out what the problem was though.
Niall
Message 23 of 24
(986 Views)
no, just change the data layout input constant from "interleaved" to "decimated", and rearrange the data inputs to match.
interleaved means that you write a sample at a time: for a 2d array that would mean each row is a sample.
decimated means that you write a channel at a time: a 2d array would have each channel in a row, or in other words each sample is a column.
what you have is a 1d array that is one sample.  wire it to a build array node to change it to a 2d array.  now it's a an array of size Nx1: one row exists in the 2d array.  Transpose this array to get a 1xN array: one column of N channels.
to illustrate:
Oh, and you only need to do this where you are writing an array of channels.  The documentation says that all channels in a group need the same layout setting.  You can change your single channel writes (time) from interleaved to decimated without rearranging the input array.
-Barrett
CLD
Message 24 of 24
(979 Views)
