buffer being kept full? One step not working after another, even though they're in series
I'm having trouble getting LabVIEW to give me both px and vx information, per attachment.  If I toggle the Boolean button, one of the 2 works, if I toggle back, the other of the 2 works.  I have a suspicion the area where I give it instructions for ac, sp, dc, etc. is tying up the connection, but A) I don't know how to get arround it, B) I'm not certain that's the problem.
Any suggestions?
Thanks!
p.s. I'm a very novice LabVIEW user and the program was written by somebody else who left no documentation for me.
Message 1 of 11
(3,616 Views)
It would be very helpful to people helping you if you post the code instead of screenshots. Why are you setting the VISA receive buffer size to the default after every read?
LabVIEW 2012
Message 2 of 11
(3,599 Views)
That is the Flush buffer not Set buffer size.
taguhi,
Do you get any errors?  What makes you think the problem is what you suspect?
As Steve said, please post your code.  It is quite difficult to debug a picture.
Lynn
Message 3 of 11
(3,581 Views)
Lynn
And without the context help it is difficult to identify functions that I do not use.
LabVIEW 2012
Message 4 of 11
(3,577 Views)
I looked it up.  I do not use it either.
Lynn
Message 5 of 11
(3,572 Views)
Yea, I looked it up too. The two look very similar and I got the wrong one.
This is a very good example of why people should always post code and not images.
LabVIEW 2012
Message 6 of 11
(3,563 Views)
Folks,
Thanks so much for the quick responses.  I was not near the computer to respond on time.
My colleague has fiddled around with the program a little more, but I'm still pretty sure that the communication line gets hung up between giving it instructions and querying for status.
This time I have attached the code.
Thanks again!
Message 7 of 11
(3,523 Views)
Just because I asked for help the problem is solved.
Thanks for all your help.
Message 8 of 11
(3,517 Views)
For the benefit of others who may think they have a similar problem, can you please report what you found and how you fixed it?
Thank you,
Lynn
Message 9 of 11
(3,491 Views)
Per Lynn's suggestion, I have attached the updated code.  The problem was solved by having the 2 sets of data querying operations in series, with a time delay in between.  Whereas I had a time delay between the 2 operations, but they were in the same case structure.
I'm now working on a whole new problem that's driving me up the wall, but this one is solved.
Thanks!
Message 10 of 11
(3,483 Views)
