browse button problem
The problem with my browse button is that it keeps asking the path every time I open the vi, though it is outside the while loop. After selecting the path, it doesnot appear in the path control. Any samples will be helpful.I am using LV 6.0 ver
(3,365 Views)
Hightlight your execution and see what happen.
Post your VI and I want to take a look.
Saw
(3,365 Views)
Hi Hema..
I have used the browse button in the while loop and I havent faced any problem, and when I run the VI and click the browse button to select the path it appears in the control too.
Veena.
(3,365 Views)
hi veena,
i am using a file path control which i have wired to read or write to excel sheet path. As soon i open the vi, before clicking on the browse button, the choose path to open or save opens up which i don't want.
can u help on this.
thanks
(3,365 Views)
You can use the browse button to select a file before you run the VI. The read/write function you're using probably has the File Dialog function set to run if there's an empty file path provided. If you want to use the browse button after starting the VI, you'll have to put in a while loop the checks first to see if the path is empty or not and as soon as it's not empty, proceed to the reading or writing of the file.
(3,365 Views)
If u can post your VI, I can take a look...
Veena
(3,365 Views)
As it so happens I just posted some code to a fellow with what sounds like a very similar issue. This code uses a dialog box to get the inital file name, but other than that the theory is basically the same. See is this gives you any ideas.
Failing that, as a couple other folks have said, if you could post some code it would help.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,365 Views)
