broken line
I have a broken line problem in a program using LV 6.0. Hope someone can help. The program is attached.
(3,195 Views)
You have two or more array data types wired together, but the arrays have different numbers of dimensions. Show the Context Help window to see how many dimensions are required.
The dimension of (unnamed) is 2.
The dimension of (unnamed) is 1.
-Khalid
(3,195 Views)
How to change the dimension?
(3,157 Views)
Hi
At each array you could set the index. Resize this control and you have more dimensions.
Hope this helps.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,153 Views)
Or just right-click on the index terminal and select "Add Dimension". 😄
(3,129 Views)
