break in code
hi everybody i developed one application and for that application i already don some coding. Now in block diagram it is showing broken arrow but when i clicked on this broken arrow it exists from labview  by giving some error.Due to this i can not find out error in my block diagram. If anybody knows solution for this please help me for it.
Regards
Falgandha Mohire
(3,749 Views)
Hi mom,
is there a error definition in the error window? Which LabVIEW version do you use? Can you upload the vi?
Mike
(3,729 Views)
Could it be related to this?
(3,716 Views)
i am using labview 8.2 and i can't upload the vi because i canot send any vi from my pc access restricted
thanks and regards
falgandha
(3,689 Views)
Did you see any error definition or LabVIEW error popup? LabVIEW may have closed without an error, but usually on your next start of LabVIEW, some sort of warning or recovery dialog will pop up and give you some information as to the cause of the crash.
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(3,650 Views)
