bools with multiple cases
Hello, I'm new to labview. I have three different cases in a case structure and I want an led to turn on when each case turns on and then turns off immediately when it leaves that case. Then the next led will turn on and turn off when it leaves the case and so on. Any guidance would be appreciated, thanks.
(1,117 Views)
Hi Dan,
THINK DATAFLOW!
You want to set an indicator TRUE inside a case and set it FALSE after the case structure!?
  • You need the terminal and a local of that indicator and two boolean constants…
  • Set the indicator to TRUE inside the case. Place the FALSE constant inside the case.
  • Set the local of the indicator outside the case structure and wire the FALSE constant to that local.
What have you tried and where are you stuck?
(1,097 Views)
