boolean troubleshooting
Hello every body I am trying to make a loop, and i got stuck at the following part. please suggest an appropriate solution: I want to make a loop which starts saving data when it recieves a 'True' from a boolean control and then bypasses the loop itself and keeps on collecting data irrespective of the boolean output. I am attaching my 'vi'
Message 1 of 18
(4,410 Views)
You could make a flat sequence with the loop in frame 1, and your data collection code in frame 2.
Jim
LV 2020
Message 2 of 18
(4,408 Views)
Thanks for replying however I would be obliged if you could explain this more elaborately. Actually if you have a look at my vi you would notice that there is only one while loop which contains both the daq and the operators, so i was wondering if i am better off with two loops or one. Vaibhav
Message 3 of 18
(4,402 Views)
To latch a Boolean, you just need a shift register as shown below. Also, from what I can tell, you have no way to stop the program unless you use the Abort Button on the toolbar. Wire a stop button to the stop input of the DAQ Assistant. For clarity, you might also want to convert the output of your Greater Than function to a single Boolean. I thoroughly despise dynamic data because it just makes it harder to see the actual data type.
Message Edited by Dennis Knutson on 06-13-2008 01:28 PM
Message Edited by Dennis Knutson on 06-13-2008 01:31 PM
Message 4 of 18
(4,396 Views)
What is the purpose of the numeric greater than 1?
Jim
LV 2020
Message 5 of 18
(4,394 Views)
thanks a ton to everybody for replying. However..I am really sorry..coz. i am a rookie. I am not sure of the shift register option because i donot have a loop around my boolean control however the idea of making the two boolean controller a single one was great. I was thinking the abort button to be the stop so i think i note that point too. As for the 1 , actually i have a voltage channel number 3 in my daq which is measuring voltage from a source when it goes above 1 v i start the data writing process to my file. vaibhav
Message 6 of 18
(4,380 Views)
What do you mean you don't have a loop around the Boolean? It's there in the VI you posted. The while loop is that squarish object around all of your code.
Never use the abort button to stop a VI. See this.
Message 7 of 18
(4,376 Views)
Thanks a ton dennis, that was really helpful now the code is running just fine.
Message 8 of 18
(4,340 Views)
Hi I am just having a small problem executing Dennis's solution. The vi does not allow me to wire the boolean or function to the shift register saying that i am connecting a dynamic data source to a boolean sink Kindly advice me how to sort out this problem i am attaching a picture and a copy of the vi.
Message 9 of 18
(4,324 Views)
As I said above, 'convert the output of your Greater Than function to a single Boolean'. That is done with the Convert from Dynamic Data function. When you configure it, select Single Scalar and Boolean data type.
Message 10 of 18
(4,316 Views)
