boolean text multiple color
HI,
In my application, I have to change dynamicly the color of a part of the boolean text. I can change the color of the entire text but not the color of a part of the text. I use the property node with the property boolText.Selection and BoolText.Textcolor.
With the color manager in edit mode, I can have multiple color for that text, so I suppose it's also possible with property node !
can someone help me for this problem ?
Thanks in advance.
GHELEYNS Nicolas
Phénix Industries.
(2,794 Views)
Hi Nicolas
You just used the wrong property. Use BoolText.FontColor instead of BoolTest.TextColor.
I attach you a simple example that shows how it works.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,789 Views)
Many thanks, it works great......
GHELEYNS Nicolas
(2,784 Views)
