boolean refnum & event
Hi
I posted this thred earlier and thought it was done but encountered another problem. Is it possible to monitor the Stop Event in StopOrWaitForTimeout.vi with boolean refnum?
Because I have two boolean controls in other SubVIs that should be able to trigger this event. If I choose the refnum event and then value changed it will only react on changes of the refnum itself and not the value of the referencd control!
ANDY
(3,899 Views)
Take a look at the attached VI. You can register events for different controls using their reference.
So in this case I registered the Value change for the stop button, using its reference. However, that reference could have been fed into this VI. So you can send a reference to a SubVI and then register its events in that SubVI.
(3,882 Views)
Hi Evan,
As I wrote in the other tread I have LV6.1. There the "register events" is not available. In 7.1 it is but neither for the base package. I'm looking for a solution in LV 6.1.
(3,876 Views)
