boolean key focus
I have an event case that executes when a boolean is pressed by the user.   In the event I set the property 'key focus' to TRUE for an string control where the user needs to enter information.   The first time the event executes key focus for the string control is not set.  The second time onward, the key focus gets set.  How come it does not get set the first time the event occurs?
(3,499 Views)
It works for me in LV2012. You might need to turn on execution highlighting to see what's happening in your code.
(3,479 Views)
Works for me.
aputman
(3,475 Views)
Yup, I've done that many times myself. Can you post an example showing the effect?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,456 Views)
