boolean in menu cluster won't read correct
I have a menu cluster of 3 booleans to do compensation on an agilent meter.  See the code, the second boolean: Measure Short will not read correctly, or long enough by labview.  This sounds like a stupid question, but I don't see what the problem is since I copied the button from the one above which works just fine.
Please help me, you should be able to just change the VISA to Com1 and probe the output of the menu cluster and see only a momentary blink of true.
Thanks in advance,
Acer05
(2,556 Views)
Your problem is in the the default case. The input to the Select function is always false unless you select Measure Open or Exit. The Measure short selection is ignored. Why don't you simply wire the output of the Search 1D Array out the case statement and into the shift register? The two compare, the or, and the Select don't seem necessary at all.
(2,549 Views)
Thanks for your help
(2,531 Views)
