boolean controls doesn't update from DS
I connected boolean controls to a tag and used the "Publish and Subcribe" option. (DS does the same).
When I toggle the control, the value changes in the plc, but when the plc changes the value the boolean control doesn't show the changes.
I've linked a numeric control to the same tag and it updates the way it should. All changes from the plc is shown in it, but not on the bool control. If I change the numeric from 0 to 1, the plc updates, but not the boolean control.
Using Labview 6.1 DSC. Coding to link 400 bool controls to the numeric controls is not an option.
(3,256 Views)
Are the tags configured to be discrete tags or numeric tags? Are they also set up as input/output tags?
Did you use the HMI wizard to link to the tag or only front panel datasocket?
I read one of your previous post(Boolean Indicator shows -1 as True I.S.O 1) and I think the problem is there:
"OPC Server is a derivate of ActiveXwhich has Variant as Datatypes.
Windows defines this datatypes in its header files... in this case in the wtypes.h
There we have the definition:
/* 0 == FALSE, -1 == TRUE */
typedef short VARIANT_BOOL;
#define VARIANT_TRUE ((VARIANT_BOOL)-1)
#define VARIANT_FALSE ((VARIANT_BOOL)0)"
The OPC Specs specify that:
"Recommendations:
· The VARIANT types VT_I2, I4, R4, R8, CY, DATE, BSTR, BOOL, UI1 as well as single arrays
of these types (VT_ARRAY) are expected to be most commonly used (in part because these are the legal types in Visual Basic).
· It is recommended that whenever possible, clients request data in one of these formats and that whenever possible, servers be prepared to return data in one of these formats.
· It is expected that use of other extended types will most likely occur where the Server and Client were written by the same vendor and the server intends to pass some non-portable vendor specific data back to the client. In the interests of interoperability, such transactions should be minimized"
Since your PLC and/or OPC server doesn't follow the norm here, I am afraid that coding is the only option you have here, unless somebody else has an idea out there...
Cyril Bouton
Applications engineering
Cyril Bouton
Active LabVIEW Developper
(3,256 Views)
Since the question was posted, the number of tags have doubled to 800 and is still climbing. I'm now trying to use a ring control in stead of booleans. This seems to do the trick. Only the behaviour is different. (shows menu of pics i.s.o changing state), but i can live with that.
Thank you very much.
(3,256 Views)
