boolean control
I want to set the boolean value to be false constant before run.
And I can change it after the program run. What should I do?
Thank you for suggestions.
Nan
(3,269 Views)
Hi Nan,
If it is a Boolean Constant (ie: FALSE), you cannot change it because it is a Constant FALSE.
The way to do it is to change it to a Control, initialize it to FALSE, then create a Property Node for Value in which you wire the last value to it.  Another way is to create a Local Variable (Property Node preferred).
But you are correct, you cannot change the value of a Constant Boolean...  A Constant FALSE cannot obtain a TRUE value.
RayR
(3,264 Views)
Another note, set the Mechanical Action to SWITCH to update the local variable or property node.  If it is set to latch it will require a variant data type.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,263 Views)
Yes... yes
Thanks Matt..
A very important point...
(3,258 Views)
