boolean array to signed integer
Hi all,
I struggling with the following:
I read a 64-bit boolean array from a device. This boolean array represents a varying collection of numbers, either signed or unsigned.
I have the composition of the array, i.e. bit 1-15 is a signed 16-bit integer, bit 16-23 is an unsigned 8-bit integer and so on...
So I can divide the boolean array into the corresponding bit-arrays to convert them to numbers. For unsigned numbers I simply use the "boolean array to number" function and that works fine (output is a U32).
Now here's the problem: This does not work for signed integers... the output of the "boolean array to number" function is always an U32, even if I select "sign extension mode"=always from the context menu of the function, so a negative value can never be extracted.
Any suggestions of how to solve this? I've tried typecasting but I can't get it to work.
PJ
(5,647 Views)
Accepted by topic author Pianne
Hi Pianne,
right-click the BoolArrayToNum function and set the correct output datatype in the properties!
(5,644 Views)
Just right-click the "Boolean Array To Number" primitive, select Properties. On the Output Configuration tab, set the desired representation.
(5,643 Views)
DOH!   Smiley Embarassed
Thank you very much!
I overlooked that.
PJ.
(5,638 Views)
