blocking the stop exeution button
hi
im runing in which i dont want the user to simply push the stop execution button but to push another one how starts a shatdown sequence
how can i block it from happening or in other words which event should i use to do so???
thanks
shai
(3,243 Views)
i have made a mass .....
what i ment was that:
im runing a VI in which i dont want to allow the user to simply stop the execution.
(3,241 Views)
Accepted by topic author shaicoh
Best practice is to hide the Abort Execution button when the VI is running. Instead, place a stop button on the front panel. Doing so, you can easily enable/disable or show/hide this button by the use of property nodes.
Read several times on NIs forums : Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,236 Views)
Hi JB,
Even i am facing the same problem, so for that i had used two buttons on above the other, one for START and another for STOP. I will be making the button visible and invisible accordingly.
I was searching if there is any other method to do the same.
Any solution will be appreciable,
Yogesh
(3,102 Views)
