blink while alarm on using shared variables with remote panel
I am creating an application where I have front panel indicators data bound to shared variables.  I also set it up to have them blink when the alarm is on.  I am using the DSC module.
This works great under the development environment.  But when I connect using the remote panel, I can no longer see the blinking indicator if there is an alarm.  I can see the blinking indicator on the machine that is running the program, but no on any of the remote panels (I have no problems connecting to the remote panel and controlling the program).
I have the remote panel set as embedded, since I want the user to be able to change some settings over the network.
I am sure I am missing something simple, any ideas??
thanks
Kenny
(3,941 Views)
Hi Kenny,
This was reported to R&D (#4766TTJ0) for further investigation. Thanks for the feedback!
Tunde
(3,920 Views)
I should also point out that I am using LV 8.20 and DSC 8.2.
Thanks for the update.
Kenny
(3,915 Views)
I have been using IE6 and Firefox, and I have found that the blinking does show up, if you refresh the page.  And then if the alarm stops and the blinking stops, you will not notice it until you refresh again.
Kenny
(3,893 Views)
