blank export image graph
I am writing the image locally, and it fails no matter whether a folder is made or not.  In the first example I had they image save twice, is that what you were talking about when you mean create a dummy image?
The image that ends up being saved on the first run through is the exact size of the graph, however it is just completely white.  So it is copying something, just not the whole thing.
Message 11 of 14
(596 Views)
That's quite strange. Is there an error out of the Export Image method?
Message 12 of 14
(592 Views)
It should not make a difference, but try to do the following:
Right-click the graph and select: "Advanced...synchronous display"
Message 13 of 14
(590 Views)
I switched it so the front panel is displayed while it runs, and it seems to have fixed the problem. Thanks for all the help.
Message 14 of 14
(574 Views)
