bitmap overlay
Hi there,
I'm having an 2048 x 4000 grayscale image. If I overlay the image with an RGBA bitmap it works well as long as the magnification
is 1/1 or lower (1/2, 1/4, etc.). For a magnification of 2/1, 4/1 or higher, the bitmap overlay suddenly disappears and scrolling becomes slow.
What's going on here ?
Ted
(3,307 Views)
Hi Ted,
Could you post a example so we can take a better look at it?
Karsten
(3,288 Views)
Hi Karsten,
I've attached the source with an image.
Thanks for your help !
Ted
(3,279 Views)
Hi Ted,
I've been able to reproduce the issue. I did some checking and the issue has recently been reported to R&D to be investicated.
As a work around you can use the Overlay Points VI  instead of the Overlay bitmap vi.
Karsten - NI
(3,263 Views)
