bit array
I have an array in labview of u8 numerics. Each numeric is a bit (1 or 0). Each u8 numeric is a byte large, which for an array representing 100 bits would be 100 bytes = 800 bits (8 times as large). Is there a way to represent single bits (1 and 0's ) in labview efficiently.
Thank you,
-Tim
Message 1 of 14
(6,743 Views)
Does that mean a U8 true is 255 (all 1's) and a U8 false is 0 (all 0's)?
How about this?
Message Edited by Ravens Fan on 07-13-2007 11:04 PM
Message 2 of 14
(6,740 Views)
Or with a simpler alternative.
Message Edited by Ravens Fan on 07-13-2007 11:11 PM
Alternative #3 added.
Message Edited by Ravens Fan on 07-13-2007 11:15 PM
Message 3 of 14
(6,739 Views)
Message timed out before I got #3 in.
Message Edited by Ravens Fan on 07-13-2007 11:18 PM
Message 4 of 14
(6,733 Views)
I meant by 1 and 0 that the lsb (least significant bit) of each U8 numeric is 1 and 0. So we have in binary for each u8 element of the array 1 and 0.
Thank you for your reply,
Tim
Message 5 of 14
(6,724 Views)
Even more simplified....
Message Edited by Bill@NGC on 07-13-2007 10:25 PM
Message 6 of 14
(6,718 Views)
LabVIEW 4.1 was the last version that stored an array of booleans in packed format. A boolean array now is an array of bytes so converting U8 to boolean only makes a copy of the data. You can use run length encoding or bit packing to compress the data but the both have access problems.
Message 7 of 14
(6,703 Views)
Are there functions in labview to do run lenght encoding and bit packing in labview, or would I have to implement these myself?
Thank you,
Tim
Message 8 of 14
(6,699 Views)
Really not so hard, just tell LV8 to treat the boolean array as though it were LV4...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 14
(6,688 Views)
Hi mikeporter,
Which version of labview are you using? I am using 8.2 and I only see a convert to 7.x in my unflatten to string, and flatten to string functions. I do not see the convert to 4.x on my functions. Also, I looked in this site
http://digital.ni.com/public.nsf/allkb/3B60483A50030258862565BC00733B89
and it says that in labview 4.x booleans are treated as 16-bit numerics which is more memory intensive than in newer versions of labview where a boolean is just a single byte (8 bits).
-Tim
Message 10 of 14
(6,653 Views)
