binary to decimal
Hi All
i want to convert binary array to decimal number. give me some idea
(16,278 Views)
Try looking on the function pallet where you might expect it to be?
(16,273 Views)
Functions-->Progamming-->Boolean-->Boolean Array to Number
=== Engineer Ambiguously ===
(16,251 Views)
If the binary array that you talked about is in boolean format (an array of T and F), you can use Boolean array to number.  If not, you can write a loop to convert the 1, 0 to boolean and use the boolean array to number function.
Yik
(16,248 Views)
If the binary array is an array of 0,1s feed it into a Not Equal To 0? and then the boolean array to number function
Omar
(16,239 Views)
Thanks All
(16,198 Views)
