big endian format using DAQ6259
I need to send 4 bytes serially shift transmit byte register (big endian format) using a DAQ card 6259 but I really do not know how to do it. Please help
(2,759 Views)
Hi Raul,
Thankyou for posting to the National Instruments Discussion Forums.
I would start with the DAQ Assistant to write any digital data to the digital port. Also I would look at the Getting Started with DAQmx series (Linked below)
Also if you would like to perform hardware timed output I would look at this example.
Hope this helps!
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(2,742 Views)
