I wonder what kind of daqmx measurement type that suit for closed loop control system with about 128 control loop?
I have design single closed loop system with continuous sample and on demand sample. Both response good. But I don't know if the control loop number is increasing.
Another question is, is clock time synchronization necessary for this kind of system?
已解决! 转到解答。
taov,
What do you mean about 128 control loop? Could you explain a little bit more about your app?
Hi Carmen,
Thanks for your reply. Sorry, I made a mistake on my last explanation. That's not measurement type, but acquisition mode. Below is the detail of my project:
I'm developing a control system for fatigue tester with 100 more sensor (load cell) and actuator (servo valve to drive cylinder). Each actuator has its own PID controller. That mean I need about 100 more PID controller. It is OK since PID vi able to handle multiple input in single loop. I used several PXI controller. The thing that bothering me is :
