baucwen hysteresis model in labview
I want to design a LabVIEW VI for baucwen hysteresis equation. I have attached the equation with parameters. I tried to develop it on LabVIEW but facing problem in feedback node. Not able to get the feedback after the Inegration. i have attached the labview VI. I designed this model in MATLAB Simulink environment and i got the result but not able to get result in LabVIEW VI. Please help me.
Thank You
Message 1 of 13
(3,492 Views)
Hi prasad,
Simulink will try to calculate that algorithm sample for sample (internally):
The problem was: the feedback node wasn't initialized, so gave an empty array on first call. Trying to calc some math with empty array will also result in empty arrays…
Message 2 of 13
(3,479 Views)
can you please share that VI file
Message 3 of 13
(3,472 Views)
Hi prasad,
it's a snippet…
(Everything is visible in the snippet, so you can easily recreate it!)
Message 4 of 13
(3,440 Views)
i am beginner to LabVIEW and facing problem in connecting to the derivative block. it will be very helpful if i get the VI file
Thank You
Message 5 of 13
(3,433 Views)
Hi prasad,
as can be seen by the icon it's the "Point by Point Derivative" function. (The same "pt-by-pt" applies to the integrator.)
Message 6 of 13
(3,429 Views)
I have recreated the VI and attached the same. But i am not getting the result as per the MATLAB Simulink. Please suggest me the correction that i can do to get the result. I have attached the image of Simulink Result.
Thank You
Message 7 of 13
(3,420 Views)
Hi prasad,
for me it looks quite nice:
Message 8 of 13
(3,411 Views)
Please suggest me any correction that i can do in the VI I have attached. Thank You so much for the result.
Message 9 of 13
(3,405 Views)
i am getting this result . I have attached the pic
Message 10 of 13
(3,401 Views)
