base64 encoding
Dave,
I have to say you are a smart guy. When I read the second line of your message, I was a little bit shocked -- how did he know ...? :)) Well, you've explained. You've read all my questions and are trying to help me out. I really appreciate that!
Yes, RedRat IR xml file used base64 encoding. That's what they told me after I contacted with them. I've tried to use their SDK APIs in Labview and so far I haven't had any luck yet. So the second option for me to create my customized IR signal dataset in labview, that I figured out, is to just change the parameters in an existing IR data file. I got everything else working but the SigData...
Thanks to you that now I've found NI's Base64Encode.vi so I can use. But I still have a problem. After running Base64Encode.vi, I got different encoded string from what's in the xml file. Looks like something else is going on...I'll have to keep exploring.
Thanks for your time and effort very much! You are right it's a fun tool and there is a lot for me to learn. 🙂
Have a good weekend!
Message 11 of 11
(738 Views)
