bar graph
hello guys,
  I am collecting data from a force transducer in one direction only.  I want to plot the data on a bar graph showing just the magnitude.  I want to retain the trace throughout the trial even if the subject has decreased the force applied, so that i can see the maximum force applied.  How can I do this.  Thank you.
Dhruvit.
Message 1 of 8
(4,765 Views)
Use a shift register to record the maximum value. Apply the previous maximum to one input of a min/max function and the current value to the other input. The maximum output goes to the right terminal of the shift register and to the bar indicator.
Lynn
Message 2 of 8
(4,760 Views)
hi dhruvit i am doing a project and i have to do same thing i have to take data from only one direction and see the maximum force so can you help me in this???
Regards
Taraq
Message 3 of 8
(4,446 Views)
Hi Taraq,
  It has been 4 years since I have worked on this project.  So I will not be able to help you with this.  Sorry for that.
Message 4 of 8
(4,430 Views)
ya i knw...its ok but as this is my master project i guess if u have can find the program and can upload here that would be a gr8 help if you cant thn can you suggest me some stuff or send me programs that would guide me to my project ...ne ways thanks lot for replying
regards from germany
Taraq Kamdar
Message 5 of 8
(4,410 Views)
Taraq,
The idea of using a shift register and a Min/Max function to capture the maximum value from a sequence of data points is a rather fundamental LabVIEW construct.  If you have not done so yet, please consider the online Tutorials to help you get started with LV.
Also, the etiquette on this forum is to use complete words (except for things like LV for LabVIEW and VI for virtual instrument) rather than texting-style abbreviations.
Lynn
Message 6 of 8
(4,403 Views)
thanks Sir for letting me know as you can see i am new to this field and forum so i did not know it
Sorry
Taraq
Message 7 of 8
(4,396 Views)
Taraq Kamdar
"ne ways"= ????
Please don't use text message speak when communicating on the forums.  Save it for your friends on your cell phone.
Message 8 of 8
(4,390 Views)
