bar graph without joining lines
Dear all,
i ahve a 1D array which i want to show as a bar graph.
i changed the plot properties from the plot legend and set one of the bar plots.
how ever it shows the graph as bar plot but it joins the values of the plot with lines .
is there anyway with which i cud only see the bar plot and not the lines joining them?
 thanks,
Ritesh
(3,022 Views)
Hi RiteshFrom clicking on the Plot Legend,  select 'Common Plots' and then the bottom right option from the drop down list. Now you can select 'Bar Plots' lower down in the plot menu and make further changes to the appearance.
Hope this helps
Ian
(3,017 Views)
Specifically, select the "Interpolation" menu item and select the first (top-left) item.
(3,001 Views)
Hi, Thanks alot .
the interpolation method solved the job.
Ritesh
(2,978 Views)
