bar graph in 2 dimension
I want to display bar graph in 2 dimension. Each bar should represent one channel value.
In another post I did find how to change the x scale from number to strings.
TIA.
CLD
Message 1 of 13
(9,238 Views)
What are you having problems with? Do you know how to make a bar graph? If not, have you looked at the examples that ship with LabVIEW.
Message 2 of 13
(9,233 Views)
Yes I did see the examples for multiplot (XY graph). I cannot find any specific example just for making bar graph. Although I did find that Bar plots can be selected from Plot legend. I do want to display multiple channels as a bar graph. DAQ device returns data as 2D array with each channel stored as a column. Please see the attached jpg of how the channels are to be displayed.
CLD
Message 3 of 13
(9,192 Views)
Please see the attached vi. Each bar shows value of all channels and I want it not to be represented in a stack format. Any suggestions?
CLD
Message 4 of 13
(9,186 Views)
What about this guy? You can get more help by searching "bar" in example finder.
Message 5 of 13
(9,173 Views)
Yes I saw this but do not want the 3 dimension dispaly. Someway of plotting so that each bar shows just one channel value and multichannels can be displayed. Please see the image in the previous post.
CLD
Message 6 of 13
(9,166 Views)
You can view the 3D dimension in 2D. Shortcut->Visible Items->Projection Palette
I do not know if the XY Graph is able to change the bar width.
Message 7 of 13
(9,159 Views)
Thanks I did not know that 3D could be changed to 2D. Bar 1, Bar2 and Bar 3 are repeating in groups for different values and the requirement is to only show it as channel on X axis and their values would change along Y axis. The width of bars is not of concern. Did you do any other change in the code? When I change to 2D I see a stacked representation of the channels/Bars.
Another thing I tried was to plot the values once and clear the chart and then plot the next value but that of course did not create the bar appearance. It should be like  a wave plotted on the graph and as the values change is minimal it will be a smooth wave display.
CLD
Message 8 of 13
(9,129 Views)
The 3D Bar has 3 mode: detach, group and stack. What you want is group mode. Check it out from Shortcut->3D Plot Properties->Bar (page).
Message 9 of 13
(9,112 Views)
Thanks.
Seems like 3 D bar graph still does not help achieve the display format that is needed 😞 Are there any other suggestions?
CLD
Message 10 of 13
(9,101 Views)
