bar graph and vu meter
I would like to know if it is possible to make a vu-meter with two hands like on this picture ?
Both hands is used to indicate the level of two input signals. It is important that both hands are on the same display.
I have a second question about the bar graph. Do you know if It is possible to make an audio bar graph with a cursor (red) which indicate the peak each second ? The behavior is the same that a classic digital audio vu meter.
Thank you for your responses.
(4,672 Views)
Hi syndrom,
with a right click on your tank, you can add another slider. The data type of your indicator becomes a cluster, so you can give two different values to it.
Edit: Maybe the attached example helps.
Hope it helps.
Mike
(4,659 Views)
