06-01-2010 06:12 AM
06-01-2010 06:23 AM
06-01-2010 07:47 AM
06-01-2010 08:58 AM - edited 06-01-2010 09:00 AM
What is your sampling rate?
Your amplitude modulation might indicate that you passed the nyquist freq. 🙂
Even at 100kS/s you will see that kind of result.
Have you provided a path for the bias current?
06-01-2010 09:03 AM
The gain bandwidth product for a TL081 is 3 MHz. At 40 kHz and a gain of 12.5 you have 0.5 MHz. This leaves only a factor of six for the feedback network. The open loop phase shift is about 90 degrees. I suspect that you have created a fine oscillator.
If you need a filter at 40 kHz, use a faster amplifier or less gain. If you need to use the TL081, build the filter with unity gain, then amplify the filtered results, possibly using two stages of amplification, each with a gain of about 3.5, rather than trying to do all the gain in one stage.
Lynn
06-01-2010 09:07 AM
06-02-2010 05:20 AM
06-02-2010 05:41 AM - edited 06-02-2010 05:45 AM
It's a well known fact that amplifiers oscillate, while oscillators don't 😉
It's OT but post the shematic and a pic of your board and the analog addicted here will take a look.
Have you buffered the OP power supply?
06-02-2010 07:29 AM
Sorry about this round about way of posting the schematic but this was really the only way I had.
06-02-2010 08:18 AM
You really did not mean that R3 and R6 were 6 ohms, did you?
According to my filter book (Williams, Electronic Filter Design Handbook), the open loop gain should be well in excess of 2*Q^2 at the resonant frequency. Since you specified a bandwidth of 2 kHz and a resonant frequency of 40 kHz, Q = 20. The open loop bandwidth of the TL081 at 40 kHz is about 100. This is probably marginal excess gain.
Ar is gain at resonant frequency. Ar' is desired gain at resonant frequency.
R2 = Q/(pi*f*C) = 58 kilohms.
Ar = 2*Q^2 = 800 !!! This is greater than the open loop gain of the op amp!!!
R1 = R2/(2*Ar) = 36 ohms
R3 = (R2/2)/(2*Q^2 - Ar') = 28 kilohms (for Ar' =1)
The specifications you gave are not compatible with this circuit at 40 kHz using the TL081.
Lynn
