background image tab control
i use labview 8.20
is it possible to add a background image to a tab control ?
i only see, that i can change the color. or change the background image from the complete background.
but i dont't want to make my tab control transparent, because then i can't see the registers (tabs with the text) of the tab control.
is there a solution ?
(5,795 Views)
I do not believe that you can do it directly. You could add a picture control to each tab and place it behind the controls and indactors to achieve the same effect.
Tim
GHSP
(5,792 Views)
Or, if you don't want to change it programmatically, just drag a picture (eg a PNG file)  onto the tab.
(5,787 Views)
