axis count
I'm currently working on a tool which allows graph manipulation..... I want to keep the code generic, hence my following problem.
I need to be able to set the axes programatically to autoscale or not, but I have a slight problem.  I can't find any way to determine the number of X-axes or Y-axes on a graph short of trying to set the index and wqaiting for an error.  Is there not a better way to do this?  Why is there no axis count property?
Shane.
(3,424 Views)
Hi Shane,
you can use the error method to count the available scales before really using it. Smiley Happy
Mike
(3,421 Views)
Ah, that's true.
Since the number of axes can't change during run-time it's a one-off thing for each graph, right?
That's not so bad.
 Thanks.
Shane.
(3,418 Views)
yes, afaik it´s not possible to change it at runtime.
Mike
(3,412 Views)
