‎03-09-2012 02:08 AM
is there a way of detecting available wireless networks and getting there MAC address and signal strengtth? I have seen a previous post that suggests using .NET, just hoping there is an easier way. Unfortunatly its on XP. if it was a later version of windows i could use net wlan at the command prompt.
the project is in LV8.6 on xp
Thanks in advance
‎03-09-2012 02:13 AM
sorry the windows 7 command is netsh wlan show.
‎03-14-2012 04:28 AM
Could you make use of the wlanapi?
http://msdn.microsoft.com/en-us/library/windows/desktop/ms706749%28v=vs.85%29.aspx
It looks as though it might take a bit of playing to get it to work but you should be able to call the DLL in LabVIEW.
Is this of any help?
‎12-19-2017 04:50 AM
I have created a Community Example Program which probably suits your needs. It performs the scanning of WiFi hotspots nearby, lists them in a ring, shows available network profiles and connects to a chosen hotspot (kudos welcome
WiFi Network Scanning and Connecting with LabVIEW - Discussion Forums - National Instruments
https://forums.ni.com/t5/Example-Program-Drafts/WiFi-Network-Scanning-and-Connecting-with-LabVIEW/ta...
